Suplemental Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2012, 09:12 AM   #1
Suplemental hot water heater
I have a Slant fin hydroponic heating system that currently supplies our hot water. It is not very efficient in supplying a continuous supply of hot water. I believe it is considered a tank less system as it holds no more than 2-3 gallons of water plus what is in the lines. I was thinking of adding a Marathon 50 gallon 240 Volt electric hot water heater (foam insulated with resin tank). My Question is, do i isolate this from my current hot water supply? OR can i leave it in line and help reduce fuel costs??
douglase is offline   Reply With Quote
Old 10-03-2012, 08:24 PM   #2
Rewards Points: 1,214
Separate it completely that way you can leave your boiler off all summer. What you can do is pipe the electric water heater with a piping arrangement from the existing heater with a couple valves that way if the electric ever breaks you can open your valves and have hot water from your original system.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
douglase (10-03-2012)
Old 10-03-2012, 09:36 PM   #3
Rewards Points: 582
agree with coldiron keep seperate with valves..... ben sr
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
