-   -   Suplemental hot water heater (http://www.diychatroom.com/f7/suplemental-hot-water-heater-158813/)
douglase 10-03-2012 08:12 AM
I have a Slant fin hydroponic heating system that currently supplies our hot water. It is not very efficient in supplying a continuous supply of hot water. I believe it is considered a tank less system as it holds no more than 2-3 gallons of water plus what is in the lines. I was thinking of adding a Marathon 50 gallon 240 Volt electric hot water heater (foam insulated with resin tank). My Question is, do i isolate this from my current hot water supply? OR can i leave it in line and help reduce fuel costs??
COLDIRON 10-03-2012 07:24 PM
Separate it completely that way you can leave your boiler off all summer. What you can do is pipe the electric water heater with a piping arrangement from the existing heater with a couple valves that way if the electric ever breaks you can open your valves and have hot water from your original system.
ben's plumbing 10-03-2012 08:36 PM
agree with coldiron keep seperate with valves.....:yes: ben sr
