Old 01-14-2013, 02:21 PM   #1
Super choked toilet,won't flush
this toilet won't flush no matter how many times i tried, the toilet is 17 years old and been used with hard salty water, any guesses and suggestions if some salt built-up or something that may have deposited over years of continuous usage, how to cut through the salt that has narrowed the hole? I think the salt build-up is predominantly the reason why the toilet won't flush
diyguy4 is offline   Reply With Quote
Old 01-14-2013, 02:26 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Brand new toilets are reasonably Cheap... Get 1...
Old 01-14-2013, 02:53 PM   #3
Is it really the drain that's plugged up?
Does water fill up the tank and come out the holes under the rim when it's flushted?
If you dump a 5 gal. bucket of water in the bowl does it go down?
Old 01-14-2013, 03:42 PM   #4
Roofmaster
Salty Water?? Is the waste pipe cast Iron? Probably the pipe from the toilet.
It easy enough to pull the toilet and look?
" A lot of men build things, and a lot of things fall down "
Old 01-14-2013, 10:27 PM   #5
the big problem is, its a squatty potty embedded into the ground with a cement finish.... it can't be moved at all...
Old 01-14-2013, 10:37 PM   #6
bulldoze the house and start over is what i am hearing as the solution.
redman88 is offline   Reply With Quote
Old 01-15-2013, 01:52 AM   #7
nice joke man but i hope you suggested a solution anyways
Old 01-15-2013, 01:54 AM   #8
the water stays in the bowl the water doesn't go down, it looks like a pond
Old 01-15-2013, 01:58 AM   #9
and yeah if you use a custom plunger made with an old towel wrapped around a traditional plunger, it does push the water down, some relatives may show up in a week and i haven't got enough time on hands to get it replaced and save my a$$ from humiliation!!
Old 01-15-2013, 10:03 AM   #10
Bondo's Avatar
Ayuh,.... Sounds like yer lookin' for an "Easy Button", insteada just Fixin' the thing...
Unfortunately, there Ain't no Easy Button...
Old 01-15-2013, 10:04 AM   #11
Roofmaster
So you give us a non standard situation wherein your toilet is set in concrete, (Who the hell does that?) Your toilet is supplied with salt water (Who the hell does that?) You dont tell us how the waste line is piped. (Dumps into the Ocean?) and you dont try to dump a five gallon bucket of water down the drain like one poster described, and let us know what happened.
Yeah the bulldozer guy was right, or Composition C-4. It sounds like your (house?) was plumbed by Rootie Kazootie.
Old 01-15-2013, 10:15 AM   #12
Drain lines plugged up, vents plugged up, septic tank is full, leach field has failed.
Old 01-15-2013, 02:08 PM   #13
All I'm asking is how to get rid of the salt deposit caused by the hard water usage? just let me know some way i could use to cut through the salt. i put my fingers through the hole and found out that it is no wider than the circumference of my thumb and thus i have concluded that it is the salt deposit that has caused me all this trouble.
Is there any chemical or product that could be employed to fixing this?
Old 01-15-2013, 02:44 PM   #14
Lightfoot's Avatar
lime-a-way is a product often used to loosen calcium/mineral deposits on shower heads, but i don't know about salt, and i don't know about using it in a toilet. I have had toilets with major mineral deposits before, but i was able to pull them up, and feed a small log chain thru them with a string and shop-vac, and then carefully work the chain back and forth to break up the deposits. I have also broken a toilet by doing this, so it's a last resort. I suppose since your toilet is cemented to the floor (i still find it hard to believe that anyone would do that), it's not an option for you.
Lightfoot is online now   Reply With Quote
Old 01-15-2013, 03:54 PM   #15
call me E
TheEplumber's Avatar
Try some Clobber and a toilet auger- careful with the stuff- read the warning labels!
http://www.herchem.com/specs/clobber.pdf
Tags
choke problem, toilet
Is there a standard flush valve that will fit a Mansfield 160? pateras Plumbing 0 09-05-2012 04:27 PM
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 07:53 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 08:17 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 08:48 PM
