Sump To Sewer, Sewer Gases - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2011, 07:36 PM   #1
Rewards Points: 83
Sump to sewer, sewer gases
hi,
I have a home with a backup sump that goes into the city sewer,( apparently the city is fine with it.)
There is a check valve as any sump would have, however I wonder about sewer gases finding their way back thru into the home either thru the pump or the 1/4 hole in the pipe by the pump (for air lock?). Im not sure what the previous owners plan exactly was.
Anyway, is it virtually impossible for bugs, sewer gases, etc. To come back thru the pipe, OR should I retrofit,insert a trap like you would see under a sink to prevent this?
thanks.
bergerdude is offline   Reply With Quote
Old 11-29-2011, 07:38 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Water bugs, frogs, lizards, snakes, mice, all come to mind.
Old 11-29-2011, 11:03 PM   #3
Rewards Points: 83
so I doubt frogs or lizards, but possibly mites or sewer gas.
So what's the waynto handle this?
Old 11-30-2011, 09:54 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you have a check valve, then the discharge line is always full of water, right?
Journeyman Plumber
Old 12-01-2011, 07:11 PM   #5
Rewards Points: 16
My main sump has a check valve in the line about a foot from the top cover of the sump pit. I guess that pipe has water sitting on top of the check valve....?? hmmm
Is that true ?
That would simply things ALOT, is that what you are trying to get me to understand?
maxim1 is offline   Reply With Quote
Old 12-01-2011, 07:14 PM   #6
Rewards Points: 12,856
The check valve will stop any gas or insects.
Never head of a public sewer system allowing sump pump to drain into there systems. Most would have a fine if you did so.
Sump drains to sewer butchbs1985 Plumbing 8 09-06-2011 12:14 PM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 12:10 PM
Sewer smell in sump pit (house is on a septic system) NateDogg1955 Plumbing 2 12-18-2009 06:01 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
