Sump Pumps - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2008, 07:39 AM   #1
Sump Pumps
Is there a sump pump that I can get that won't rust up, and burn up the motor after 2 years. One I can get for less than $800 bucks. At a $200 pump per year I am getting frustrated.
RobertS is offline   Reply With Quote
Old 02-22-2008, 10:57 AM   #2
The wayne company makes sump pumps in many materials from Stainless steel, thermoplastic and cast iron and in many HP. They are guaranteed for 5 years and some have lifetime warrantees. Typing Sump Pumps into your searchbar will give you a lot of companies to check-out.
http://www.waynepumps.com/producttyp...oducttypeid=22
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-22-2008, 12:28 PM   #3
How much water do you need to remove per day, per week, per month?
It would be better to reduce the amount of water that gets to the sump pump. Direct all water away from the home. Have all downspouts divert rain water at least 10-20 feet away from the home.
redline is offline   Reply With Quote
Old 02-22-2008, 03:34 PM   #4
I blame ProWallGuy
Rewards Points: 150
What brand/model are you using now? Where are you buying the pump? Are you sure its the right pump for the job?
Sump pumps have to work in harsh environments and we demand quite a bit of them. The one you keep buying isn't up to the task if you're only getting two years from it, but perhaps you're working the fool out of it, or its not intended for the particular installation you have it in.
Tell us more about it.
Double A is offline   Reply With Quote
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 11:33 AM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
