Old 09-19-2007, 07:40 AM   #1
sump pump where does it empty to ?
Hello
At my son's Home he has been in for two years I noticed his sump pump dumping into a 4" pipe going into the ground behind the house. I wonder where does this go? My son was never told and we just wonder if there is a code that determine's where this should go?
Deck hand
deck hand is offline   Reply With Quote
Old 09-19-2007, 10:40 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What dumps into this pit?"
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 09-19-2007, 11:25 AM   #3
Probably out into the yard........ Not much "code" for runoff / Sumps in residential applications..... other than not hooking into the sanitary lines....
mdlbldrmatt135 is offline   Reply With Quote
Old 09-20-2007, 03:52 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Residentail sump pump discharge could go almost anywhere...piped into a drainage ditch, a "dry" sump pit, an underground perforated drain tile, a sewer or septic system, or just out on the surface of a yard, etc., unless there are some local code restrictions.
No telling. As long as whatever it is isn't plugged up and it takes all of the sump pump discharge with no problem, I wouldn't worry about it.
If that 4" pipe is "open", I would wrap it with something to prevent dirt, leaves, debris from eventually clogging it, however.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-20-2007, 11:46 AM   #5
thanks mike
Old 09-20-2007, 05:29 PM   #6
In Canada, some jurisdictions by code determines whether it goes to storm drane or sewage. So it may depend where his home is....
slakker is offline   Reply With Quote
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
Sump Pump Question cibula11 Plumbing 9 04-26-2007 04:28 PM
Sump Pump Help bolumenb Plumbing 4 01-22-2007 05:30 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
