-   -   sump pump where does it empty to ? (http://www.diychatroom.com/f7/sump-pump-where-does-empty-11667/)
deck hand 09-19-2007 06:40 AM
Hello
At my son's Home he has been in for two years I noticed his sump pump dumping into a 4" pipe going into the ground behind the house. I wonder where does this go? My son was never told and we just wonder if there is a code that determine's where this should go?
Deck hand
Ron The Plumber 09-19-2007 09:40 AM
What dumps into this pit?"
mdlbldrmatt135 09-19-2007 10:25 AM
Probably out into the yard........ Not much "code" for runoff / Sumps in residential applications..... other than not hooking into the sanitary lines....
Mike Swearingen 09-20-2007 02:52 AM
Residentail sump pump discharge could go almost anywhere...piped into a drainage ditch, a "dry" sump pit, an underground perforated drain tile, a sewer or septic system, or just out on the surface of a yard, etc., unless there are some local code restrictions.
No telling. As long as whatever it is isn't plugged up and it takes all of the sump pump discharge with no problem, I wouldn't worry about it.
If that 4" pipe is "open", I would wrap it with something to prevent dirt, leaves, debris from eventually clogging it, however.
Good Luck!
Mike
deck hand 09-20-2007 10:46 AM
thanks mike
slakker 09-20-2007 04:29 PM
In Canada, some jurisdictions by code determines whether it goes to storm drane or sewage. So it may depend where his home is....
