Sump Pump: What Is This On Bottom Of Float? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2014, 03:37 PM   #1
Rewards Points: 12
Sump pump: What is this on bottom of float?
See the attached pic of the float on a Zoeller sump pump. What is the black rubber thing on the bottom? Should this be attached somewhere on the pump or someplace else?
The float dances around a bit, and gets stuck once in a while. I wonder if this is meant to anchor the float...would make sense.
Thanks!
Sump pump: What is this on bottom of float?-img_2661.jpg
maxxjr is offline   Reply With Quote
Old 04-05-2014, 04:18 PM   #2
Rewards Points: 350
Welcome to the forum Maxxjr.
I'm not sure, but it could have been used as some kind of tether at some point to raise the float. Maybe the float wasn't raising high enough to engage pump. Just a thought.
If float is getting stuck, reposition it so it floats freely. Other than that, if pump is working I wouldn't worry too much about it.
Stay tuned, others will be along shortly with more suggestions/advice. Thanks.
jmon is offline   Reply With Quote
Old 04-05-2014, 04:40 PM   #3
Rewards Points: 2,068
Look to find where the hole in the rubber thing might fasten to keep the float upright.
Scroll down about half way in this link and the black pump has something similar to your rubber piece but it can't be seen where exactly it connects.
http://pumpzzz.com/2651-sump-pump-fl...ch-repair.html
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
jmon (04-05-2014), oh'mike (04-06-2014)
Old 04-05-2014, 06:33 PM   #4
Rewards Points: 350
Good advice fairview. That makes sense. Probably just rusted off/broke loose.
Old 04-06-2014, 06:46 AM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Yes, that piece connects to the pump to keep the float upright and from dancing around. They dont often come loose, but it happens from time to time.
JDC is offline   Reply With Quote
The Following 2 Users Say Thank You to JDC For This Useful Post:
jmon (04-06-2014), maxxjr (04-06-2014)
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 10:42 PM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Plumber put 1 inch holes in bottom of sump pump pit Teach1222 Plumbing 11 01-05-2012 10:59 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
