Sump Pump Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2010, 09:26 PM   #1
sump pump well
We moved into this house last year, The sump well was always filling with ground water & the pump going several times per hour.
The past month the 2 pipes have been dry & no water at all is draining into the pit, should I be concerned??
pbbdgld is offline   Reply With Quote
Old 09-30-2010, 07:38 AM   #2
Rewards Points: 1,494
Usually, if there is a long dry spell, sump pump activity is likely to be less but it may take a few weeks before activity dies down.
This has to do with the water table, which rises and falls depending on the amount of rainfall.
However if there is an underground stream very close to your house, the sump pump may always be active.
If water collects against your house when it rains, you need to regrade the land or do other corrective action to eliminate that. It is not a good idea to add drainage pipes to channel ground water or gutter water into your sump pump well.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
