Sump Pump Used On Sewer Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2013, 07:47 PM   #1
Sump pump used on sewer lines
Is it a sump pump that can be used in a sewer overflow line?
Peggy Kyzar is offline   Reply With Quote
Old 04-20-2013, 09:36 PM   #2
Rewards Points: 1,448
You can buy a self contained holding tank with pump for such purposes as installing toilets or sinks in a basement below main drain level. This is hitched up to your main drain.
You may not construct a "sump pump pit" and use it for sewage.
You may not construct a sewage overflow line that dumps out in the open or into an underground facility not approved for sewage, such as a French drain.
Old 04-21-2013, 12:55 PM   #3
Rewards Points: 352
Quite possibly what you are looking for is a sewer ejector pump. they cost a little more than a sump pump.
plumberinlaw is offline   Reply With Quote
Old 04-21-2013, 03:36 PM   #4
Roofmaster
Rewards Points: 2,172
Peggy, I'm sure that you know that sewer lines carry solids like feces, and paper and what not. A sump pump is designed for clear water, and that's all. You need a sealed unit with a masticator in it to grind up the solids. A much more complicated task than what a simple sump pump has to accomplish.
Help with Sump Pump Basin lancestorm Plumbing 5 12-28-2011 09:05 AM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 11:51 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 10:48 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
