-   -   Sump pump used on sewer lines (http://www.diychatroom.com/f7/sump-pump-used-sewer-lines-177673/)
Peggy Kyzar 04-20-2013 07:47 PM
Is it a sump pump that can be used in a sewer overflow line?
AllanJ 04-20-2013 09:36 PM
You can buy a self contained holding tank with pump for such purposes as installing toilets or sinks in a basement below main drain level. This is hitched up to your main drain.
You may not construct a "sump pump pit" and use it for sewage.
You may not construct a sewage overflow line that dumps out in the open or into an underground facility not approved for sewage, such as a French drain.
plumberinlaw 04-21-2013 12:55 PM
Quite possibly what you are looking for is a sewer ejector pump. they cost a little more than a sump pump.
jagans 04-21-2013 03:36 PM
Peggy, I'm sure that you know that sewer lines carry solids like feces, and paper and what not. A sump pump is designed for clear water, and that's all. You need a sealed unit with a masticator in it to grind up the solids. A much more complicated task than what a simple sump pump has to accomplish. :huh:
