-   -   Sump Pump Tree roots (http://www.diychatroom.com/f7/sump-pump-tree-roots-174550/)
davidtetra 03-14-2013 10:34 PM
Hello,
I've had a sewage pit in the basement installed for about 6 years, it appears tree roots are coming down the pipe that feeds from the toilet.
I'm not sure if it was installed improperly, (contractors did it) or if this is a normal unlucky circumstance.
1. Is it likely i have to dig up the bathroom floor to get to the pipe to seal the cavity around the pipe?
2. is there a natural way I can treat the pump area and kill the tree roots?
3. if I get a plumber would they know more of what to do?
Thanks in advance, having to get rid of the roots every 6 months is really, REALLY disappointing,..
AllanJ 03-14-2013 10:56 PM
Show us a picture of what you got.
A toilet should not dump into a sump pump pit.
You can buy a chemical that you pour into a drain pipe cleanout (or a toilet) along with 3 to 5 gallons of water and it foams up and kills roots. This treatment is repeated about every 4 months. You may have to auger out the roots once for starters.
Pouring the chemical into a sink drain won't work because the chemical foams up too fast to go down a 2 inch drain.
Pouring the chemical into a sump pump pit won't work because the perimeter drain pipes are pitched into the pit, not away, and the foam won't go up the drain pipes.
davidtetra 03-15-2013 12:23 AM
1 Attachment(s)
Got it,
I knew I should have done so when I had it taken apart, see attached:
Awesome, do you know of a good brand? Could you recommend?
Outstanding feedback, perhaps the picture may elicit a different option / opinion.
Thanks!
Bondo 03-15-2013 08:57 AM
Originally Posted by davidtetra (Post 1137535)
Hello,
I've had a sump pump in the basement installed for about 6 years, it appears tree roots are coming down the pipe that feeds from the toilet.
Ayuh,.... Cut down the nearest tree then....
davidtetra 03-15-2013 10:14 AM
Right, I had an equally useless idea as well. I'm just going to stop eating food,.. :)
Bondo 03-15-2013 01:51 PM
Ayuh,... Obviously there's a tree nearby outside,...
In order to grow, they send out roots to find water...
The ONLY permanent Cure is to cut down That tree...
Otherwise, yer gonna be doin' this Forever...
You could open the outside drainage, or whatever the black drainage tile in yer picture is comin' from, such as where a down-spout empties, 'n drop in a box of Rid-dex, it'll kill the roots there Now, but yer Still gonna have More roots, til ya cut the Tree Down...
If there is no other end available on that tile, there ain't a danm thing you can do, but Cut the Tree Down...
I'm sorry that Common Sense, is Irrelevant Useless Info to ya...:whistling2:
TheEplumber 03-15-2013 02:08 PM
199 Attachment(s)
That looks like a sewage pit- not a sump.
Roots seek nutrients- you've got a leak around the inlet gasket in the pit.
Seal that up, then perhaps the root killing chems as treatment
davidtetra 03-15-2013 02:30 PM
Thank you for the correction. It is a sewage pit, not sump.
Thanks to all for the help,
redman88 03-15-2013 03:29 PM
well looks like the roots are not breaking into the pipe, just coming in around the edges..... so yeah remove the tree.
Ghostmaker 03-15-2013 07:02 PM
http://www.ebay.com/itm/Rootx-2-poun...0686%26ps%3D54
Might want to apply this on them.
davidtetra 03-15-2013 07:08 PM
Outstanding, thanks for the suggestion!
