Sump Pump Stops Pumping In High Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2011, 07:34 AM   #1
Unhappy
Sump pump stops pumping in high water
I have a pedestal sump pump. It works great, unless there is a really hard rain and the sump fills up fast. The pump motor is running, but seems to not be pumping. If I toggle the float switch (off then back on), the water gets pumped out and the pump works fine again.
Any ideas why?
MrKrabbs is offline   Reply With Quote
Old 08-08-2011, 08:03 AM   #2
Rewards Points: 1,542
Is there debris at the bottom of the sump, perhaps hiding in the pump inlet?
Stopping the pump for an instant might happen to dislodge the debris temporarily.
Or maybe the impeller or other parts need tightening where now they sometimes work and sometimes slip.
The Following User Says Thank You to AllanJ For This Useful Post:
MrKrabbs (08-10-2011)
Old 08-08-2011, 09:25 AM   #3
Hi AllanJ, thanks.
Yeah, there was debris at the inlet and I cleaned it out. But, maybe there is some more, I'll check...
And I'll check the tightening too, but it should be ok because I just put this new pump in 2 months ago.
Old 08-10-2011, 05:00 PM   #4
Solved!
I adjusted the float to kick on shallower, and this solved my problem. I think what was happening is when there was a lot of water being pumped up at once, and the drain was getting full and the stop valve not closing.
Tags
sump pumps
sump pump "pit falls" bubbler Plumbing 6 03-09-2011 08:45 AM
Sump pump issues GeorgeHuhges Plumbing 3 10-19-2009 02:43 PM
Huge bang when my sump pump stops gregfroy Plumbing 7 10-13-2009 08:35 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
