Sump Pump Running Constantly And Spraying Water Back Into Pit - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2013, 05:16 PM   #16
Rewards Points: 6,652
That will do it. Hopefully he left you a spare check valve. There are also some pumps, that you can replace the relay for the float, without having to replace the whole pump.
Old 03-22-2013, 05:19 PM   #17
Rewards Points: 45
That is what he did, said there was no need to replace the entire pump.
CubsWin is offline   Reply With Quote
Old 01-04-2017, 09:25 PM   #18
Rewards Points: 2
Re: Sump Pump running constantly and spraying water back into pit
I know this is four years later but I thought it'd help anyway. I was looking for clogs in the pump itself (Small 1/3 horse electric sump - Flotec fpmm3600d) I noticed the pressure would reach about 4 feet up the pipe - 1" corrugated plastic. I went outside (Buffalo, NY in December) and the pipe was frozen like a freezie-pop. I didn't know that a straight pipe sloped from the middle could still have 100% water blockage. So I brought it inside to thaw.
del909 is offline   Reply With Quote
