Sump Pump Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2013, 03:38 PM   #1
sump pump repair
My problem is with a submersible sump pump. Flotec FPSC3250A. When it kicks in, I can feel that the motor wants to run, but the impeller doesn't want to turn and the housing gets very warm. If I give the impeller a little push, it starts to turn at what seems the normal speed. Does anyone have any ideas?
Thank you
Lars56 is offline   Reply With Quote
Old 11-18-2013, 03:52 PM   #2
Rewards Points: 232
Just a guess. Any dirt/rocks present. Maybe getting ready to fail. Can you post some pics? Thanks.
jmon is offline   Reply With Quote
Old 11-18-2013, 03:57 PM   #3
no rocks or any kind of blockage. I've got the base off and have easy access to the impeller
Old 11-18-2013, 03:57 PM   #4
joed's Avatar
Rewards Points: 12,028
dry bushing in motor?
dirt inside?
Why risk a basement flood. Replace it.
I believe those things are filled with oil. If you decide to open it do it in a large pan.
The Following User Says Thank You to joed For This Useful Post:
jmon (11-18-2013)
Old 11-18-2013, 04:07 PM   #5
Rewards Points: 13,300
Is there a hump on the side of the motor with two screws holding the cover on?
If so that's the capacitor.
It gives the motor a kick in the butt to get started.
Old 11-18-2013, 04:09 PM   #6
Rewards Points: 77
Sounds like the capacitor (if it has one) When they go it wont start but will start if ya give it a spin. Usually mounted on the side of the motor. Easy to replace also.
cyberknight is offline   Reply With Quote
Old 11-18-2013, 04:11 PM   #7
Rewards Points: 77
OOPS. joecaption beat me to it while i was typing. also saw it is a submersible. Not sure where the cap is, probably inside of it.
Old 11-18-2013, 06:27 PM   #8
I took the top off and the capacitor is there. It looks a little distorted (hump in the middle like someting blew up inside the casing.) I'll see if I can find a new capacitor. Thanks guys
Old 11-18-2013, 07:11 PM   #9
Civil Engineer
Rewards Points: 4,580
Replacing a capacitor is usually pretty easy, but make sure you understand how to discharge the capacitor before removing it. Lots of videos on You Tube to show how to properly discharge a capacitor. It can really hurt if the capacitor discharges through you. Many "dead" capacitors still hold a pretty good charge, better safe than sorry.
Sump Pump recommendations rj00005 Plumbing 2 03-03-2013 11:18 AM
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 01:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 02:55 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 06:26 AM
