-   -   sump pump repair (http://www.diychatroom.com/f7/sump-pump-repair-190600/)
Lars56 11-18-2013 02:38 PM
sump pump repair
My problem is with a submersible sump pump. Flotec FPSC3250A. When it kicks in, I can feel that the motor wants to run, but the impeller doesn't want to turn and the housing gets very warm. If I give the impeller a little push, it starts to turn at what seems the normal speed. Does anyone have any ideas?
Thank you
jmon 11-18-2013 02:52 PM
Just a guess. Any dirt/rocks present. Maybe getting ready to fail. Can you post some pics? Thanks.
Lars56 11-18-2013 02:57 PM
no rocks or any kind of blockage. I've got the base off and have easy access to the impeller
joed 11-18-2013 02:57 PM
dry bushing in motor?
dirt inside?
Why risk a basement flood. Replace it.
I believe those things are filled with oil. If you decide to open it do it in a large pan.
joecaption 11-18-2013 03:07 PM
Is there a hump on the side of the motor with two screws holding the cover on?
If so that's the capacitor.
It gives the motor a kick in the butt to get started.
cyberknight 11-18-2013 03:09 PM
Sounds like the capacitor (if it has one) When they go it wont start but will start if ya give it a spin. Usually mounted on the side of the motor. Easy to replace also.
cyberknight 11-18-2013 03:11 PM
OOPS. joecaption beat me to it while i was typing. also saw it is a submersible. Not sure where the cap is, probably inside of it.
Lars56 11-18-2013 05:27 PM
I took the top off and the capacitor is there. It looks a little distorted (hump in the middle like someting blew up inside the casing.) I'll see if I can find a new capacitor. Thanks guys
Daniel Holzman 11-18-2013 06:11 PM
Replacing a capacitor is usually pretty easy, but make sure you understand how to discharge the capacitor before removing it. Lots of videos on You Tube to show how to properly discharge a capacitor. It can really hurt if the capacitor discharges through you. Many "dead" capacitors still hold a pretty good charge, better safe than sorry.
