Sump Pump Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2009, 11:12 PM   #16
Originally Posted by skeeter 152 View Post
unless you live in a swamp that is alot of water coming in is your water meter spinning constantly? i think there is a fresh water leak under the slab
Just watched the meters for about 30 mins and not a budge. I guess being that this is my first house and not knowing how much a sump should run, I just haven't been that alarmed. Any suggestions as to how I might check it out? Thank you all for the valuable feedback!
henlij is offline   Reply With Quote
Old 08-12-2009, 02:38 PM   #17
Master Joatmon
Chucky Jesus's Avatar
I saw your video. Is the rate at which the water enters the pit constant? Does it increase after a rain storm? Does it increase shortly after a discharge cycle? Does it ever stop?
Chucky Jesus is offline   Reply With Quote
Old 08-12-2009, 02:57 PM   #18
It never stops. What you see in the video is constant as far as flow is concerned. It will flow more during a storm, but not that much more. It seems that most of the water that is coming in is always coming in, not from the rain, if that makes sense. My downspouts all drain well away from the house, grade is away (although never measured rate) and no landscaping around the house.
I mentioned in a previous post that I have the only house on our block that has a full basement. I probably shouldn't have said that as I just inferred that based on typical floor plans we'd seen from the builder and the fact that our sump pump ran all the time. I don't know many of my neighbors and am not the kind of person to go knocking door to door asking them about their sumps. I find if very interesting to find out that perhaps I should be concerned so I'll poke around our county assessors site to see if I can get some floor plans for other houses and perhaps target a couple neighbors to ask.
No need to mention that we talk to the builder. They don't stand behind anything and won't return calls. I'm glad there isn't anything seriously wrong with the house.
Thanks all!
Old 08-12-2009, 03:22 PM   #19
Master Joatmon
Looks like we can rule out sump pump discharge water getting back into the system and a water leak under the slab (you said no movement on the water meter, but you could have a leak before the meter. You might want to hire a plumber with one of those listening devices just to confirm). You just might have to keep an extra pump on hand to replace the one that is getting over-worked. I have a battery operated water sensor alarm that I keep next the sump pump lid in case the pump fails. Got it at the orange apron store. I replace the battery when I replace those in the smoke detectors: once/year Some peace of mind. I still need to get a battery backup pump in case I'm not home when/if the main pump fails.
Old 08-12-2009, 07:50 PM   #20
Idiot Emeritus
Rewards Points: 1,492
There's a fairly simple control system you could build using two floats, a relay, and a box to put it in.
The upper float would turn the pump on, and the lower float would turn it off. The floats could be adjusted as needed.
It's not hard to build, but you'd need at least some electrical knowledge. If you know what 'normally open' and 'normally closed' means, and what a relay does, then either me or any of about a dozen guys on the electrical forum could lead you through it.
Rob
micromind is offline   Reply With Quote
Old 03-16-2015, 06:30 PM   #21
I just moved into a townhouse last week and we are having a winter thaw so ground is very wet. My sump pump was running constantly so I had it replaced with a new one and a battery back up by a plumber. It's still running non-stop.
My neighbors sump pump is about 2 feet from mine. I noticed my pump is running constantly but his is not. His goes off about every 7 minutes. I don't want to burn thru a motor pumping out all the townhouses connected to me. Should I raise the float level? Any ideas or thoughts would be appreciated on why mine is running harder than everyone else's when we are all connected. Thank you for your consideration.
Jjkjulie is offline   Reply With Quote
Old 03-16-2015, 08:52 PM   #22
Rewards Points: 1,548
You can try raising the top float (raising the pump turn on level). But keep an eye on things. If the drain pipes emptying into the pit get completely submerged before the pump turns on then there is an increased chance of water coming up onto the basement floor on the far side of the baement.
Usually the system performs best when the pump turns on with about half of each drain pipe submerged.
A bed of mulch or gravel below the ground surface contour and up against the foundation will collect water rather than carry away water. This increases the load on the sump pump.
Old 03-16-2015, 10:00 PM   #23
Thank you so much!
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump pump questions CCP Plumbing 1 06-04-2009 06:09 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 08:47 PM
