Old 09-13-2009, 09:38 AM   #1
sump pump question
We have bought a house in the country. Although code calls for a sump pump, inspection is very lack. There is no sump pump nor pit. There is a floor drain/catch basin. I can see the weeping tiles( corrugated tube) where they enter this drain. I can also see another tube in the center that must go to the septic tank. It would seem to me that sending clean water to the septic system is bad design. There is no evidence of there being any back up problems. The whole area is built on a gravel ridge and has good drainage. I know the lack of a sump pump should be corrected. What is the best way of doing this without breaking up a lot of floor? Make a pit close to the drain and extend the weeping tiles to the pit? Convert the existing floor drain to a sump pit? Please excuse my ignorance on this subject. I understand city plumbing but this is new to me!
Moisheh
moisheh is offline   Reply With Quote
Old 09-13-2009, 03:14 PM   #2
sump pump question
If the house is on a high point on the property the drain my go to a dump in a ravine or a dry-well. You may not need a sump.
hayewe farm is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 49 02-27-2011 02:42 PM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 01:21 PM
Permanent sump pump drainage hose jools Plumbing 8 05-11-2008 10:37 AM
Another sump pump question vavs Plumbing 11 02-14-2008 06:16 PM
