Sump Pump Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2011, 06:41 PM   #1
sump pump problems
My sump pump back up alarm has been going off for about 2 hours now and the pump keeps turning on with extremely low water levels in the pit. It is making a gargling noise. not quite sure what is going on. The back up system is telling me to check the main pump....I have no idea where that bad boy is. Can anyone help?
emily007 is offline   Reply With Quote
Old 05-19-2011, 10:03 PM   #2
Rewards Points: 1,418
Are the floats and linkages that turn the pump on and off out of adjustment or bent?
Old 05-20-2011, 04:38 PM   #3
Rewards Points: 1,528
THe main sump pump is likely near the backup one. Look for 11/2" diameter white or black plastic pipes coming out of a black plastic round cover from your basement floor. These will usually point you to the pump's location.
bob22 is offline   Reply With Quote
How to test a sump pump sherlock Plumbing 2 10-02-2010 09:04 AM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 07:14 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
Sump pump re-hab mpking Plumbing 1 11-08-2007 12:29 AM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
