Sump Pump Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2009, 11:22 AM   #1
Question
sump pump problem
when I connect my back up sump pump to electrical outlet wire gets heated in a minute so much that I have to dissconnect it right away. why this is happening ?
rmshah is offline   Reply With Quote
Old 02-28-2009, 01:43 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Usually a back up pump is for when power is lost and the pump connect to 12v battery next to the sump. Are you sure the the pump you are plugging into household voltage is rated for that application?
Old 03-02-2009, 10:47 AM   #3
sump pump problem
No, I dont know since it was there when I moved in to the house.
Sump Punp Problem drosen4141@mac.com Plumbing 5 01-12-2009 09:48 PM
Water Powered Sump Pump acuteot Plumbing 7 11-23-2008 09:40 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sump Pump Discharge in MN livinginthepark Plumbing 5 11-12-2008 12:04 PM
Another sump pump question vavs Plumbing 11 02-14-2008 05:16 PM
