Sump Pump Pit, No Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2010, 05:34 AM   #1
Question
Sump pump pit, no sump pump
im buying house that has sump pit but no pump had it checked by surveyor says its clear water no damp no silt do i have anything to worry bout
carlo12 is offline   Reply With Quote
Old 05-08-2010, 08:37 AM   #2
Rewards Points: 1,418
Originally Posted by carlo12 View Post
im buying house that has sump pit ... do i have anything to worry bout
The previous owner or the owner before him may have taken the sump pump with him.
If the basement has flooded in the past then you know you should buy a sump pump and get it ready to use (not just sit in its box in the corner).
If the basement has never flooded before, then a surveyor can find the water table and predict the chances of a flooded basement, but cannot guarantee anything.
If your lot is higher than the neighbors' you have less of a chance of a flooded basement but again there is no guarantee. The water table can differ by a few feet from lot to lot also.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
