Sump Pump Outside Will It Freeze? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2012, 12:15 PM   #1
sump pump outside will it freeze?
I have 2 sump pits for my house. 1 is in the basement and the 2nd is outside. the one in the basement is fine. but the pump out side is toast. I am going to replace it with a zoeller 57m.
now the pit is about 10ft down to the bottom. I am worried that if I put a check valve on that the pipe will freeze up in the winter.
other thing is I am not sure if the out side pit is meant to be a over flow, back up, or what? It is only about 8ft away from the one inside. It looks like it may be a bit deeper to the bottom then the one inside.
benny27 is offline   Reply With Quote
Old 08-01-2012, 01:48 PM   #2
Rewards Points: 1,514
If the pit is deep enough or wide enough to hold a large amount of water before the pump has to start then you do not need a check valve.This lets the water drain back down to prevent freezing.
For a long time I have suggested having 3 cubic feet (a little over 20 gallons) of space below the turn on level and not filled with rocks.
With the entirety of the pump below about 4 feet and the lid at least semi-sealed to prevent air infiltration and exchange, the pump and pit should not freeze up.
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 10:42 PM
Sump pump runs all the time....help? Chris Leach General DIY Discussions 9 07-14-2011 07:00 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
Sump pump re-hab mpking Plumbing 1 11-07-2007 11:29 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
