Sump Pump Needs To Be Power Cycled Once A Week - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2009, 08:39 AM   #1
Rewards Points: 184
Sump Pump needs to be power cycled once a week
My sump pump has been going out about once a week, once, I unplug it, then plug it back it, it starts working again. When it stops, it seems like the motor is trying to run, but the alarm on my watch dog is going off.
Does anyone know why it could be doing thing? Does it need to be replaced? Is it getting clogged?
abefroman is offline   Reply With Quote
Old 02-17-2009, 09:26 AM   #2
You may need to remove it from the sump and check for trash in the impellor. You don't want to take the chance that it won't work when needed. If it sounds like the motor "wants" to run, there is something stopping it from doing so.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-17-2009, 09:32 AM   #3
Rewards Points: 184
Thanks! Is it hard to get to that? do I need to take the bottom off?
Old 02-17-2009, 10:08 AM   #4
Normally, there is a screening on the bottom of the pump and you can see the impellor. You can then use something to turn it and see if seems like it is seizing up, or anything is preventing it from spinning. If the screen has too small of holes, you should see screws to remove it.
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 10:17 AM
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 09:48 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
