Old 04-08-2011, 05:50 PM   #1
sump pump 'loud knock/pop"
Hi - I put in a new sump punp this week and attached it to the existing lines which includes a check valve (brass). When the pump completes its cycle - randomly there is a loud pop or knock - loud enough to hear upstairs on the main floor. Can anyone point me to the cause and what I could diy to address this - Many thanks
wendl is offline   Reply With Quote
Old 04-08-2011, 07:57 PM   #2
Super Moderator
That's your check valve slamming shut and shaking the pipes!
Post a picture.---Mike----
Old 09-03-2011, 08:22 AM   #3
there are devices called Water Hammer Arrestors that are supposed to quiet the type of noise you are hearing.
rvmeush is offline   Reply With Quote
Old 09-03-2011, 08:48 AM   #4
Super Moderator
I've never seen one used on a sump discharge line---usually moving the check valve up a bit helps or switching to a different style does the trick.
Old 09-03-2011, 01:38 PM   #5
MikeKy55's Avatar
I used one of these on my ejection pump and you cannot hear it even in the basement. The flapper is spring loaded and shuts as the pump pressure drops at shut off. I tried three different valves before I found this type. The other two sounded like someone jumped off the kitchen counter when it shut off.
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
oh'mike (09-03-2011)
Sump pump pit water level --- problem de12 Plumbing 49 02-27-2011 02:42 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
LOUD sump pump SusanGG Plumbing 4 09-30-2008 07:29 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
