Sump Pump Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2010, 04:44 PM   #1
Sump pump location
I'm getting ready to install a sump pump in the part of my basement that floods after heavy rain. In the corner of the basement where the problem seems to originate, the end of the raised brick fireplace hearth is 40" from the load bearing wall, extending 22" from outer wall. I understand that I need to stay 10" away from wall. Does this also include the fireplace footing? I would like to "sandwich" the sump basin between end of hearth & LB wall, staying away from outer wall minimum 10". This house is about 40 years old, so I suspect that the basement floor may have been poured directly over the red clay,(here in western NC.) Any suggestions before I rent a jackhammer?
NCWGNMKR is offline   Reply With Quote
Old 01-30-2010, 09:44 PM   #2
Can you post some pics of this area?
meboatermike is offline   Reply With Quote
Old 01-30-2010, 09:46 PM   #3
Rewards Points: 160
I had same problem...noticed my eavestrophes were spilling water the wrong way...replaced and problem solved.
hellothere123 is offline   Reply With Quote
Old 01-31-2010, 07:58 AM   #4
Rewards Points: 1,548
I would say yes you should stay 10 inches away from the fireplace footing. The fireplace and chimney are heavy and digging too close to it could also result in the earth collapsing underneath.
Suggest digging a trench along the exterior wall from the worst flooding point to the pit not as close to the fireplace. Dig no deeper than the bottom of the wall footing. Wrap a 3 or 4 inch perforated pipe in weed control cloth and lay it the trench (if there was not already such a pipe there) and connect it to the pit. Now the pit will perform equally well as a pit right in the worst area.
Old 02-01-2010, 11:23 AM   #5
Thanks, that's good advice- will look into running lines to pit.
Old 02-01-2010, 11:24 AM   #6
Posted pic on Monday morning- thanks.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
