Sump Pump Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2012, 03:28 PM   #1
Sump Pump Location
How do I decide where to put a sump pump and how do I have it drain from my basement. I live in Saskatoon, SK. I'm going to be putting a legal suite in my basement. I realize there are codes but not sure where to put the pump!
Judster is offline   Reply With Quote
Old 04-28-2012, 03:56 PM   #2
MarginallyQualified
Rewards Points: 2,464
What have the contractors you're hiring told you they'll do?
Old 04-28-2012, 08:29 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... At the lowest point, hopefully near a waste water drain....
Old 04-29-2012, 06:24 AM   #4
Rewards Points: 1,548
It's a tradeoff among low point in the basement and where you pump the water to. If the floor level varies by more than an inch, that would greatly favor the low point.
The low point has the obvious advantage in that water that got spilled on the floor (such a from a burst water heater) will flow to the pit. But you may end up with a hard to hide or headroom reducing pump outlet pipe going across the ceiling.
Perimeter drain pipes must not slope down away from the sump (pit). (Level from end to end despite a few minor undulations is acceptable.) It may be desirable to lay these before choosing the pit location. Unusual and special and usually more expensive considerations apply if you absolutely positively must run perimeter drain pipes along and below the foundation footers. You must not pump the water into a septic system and in most cities you may not pump it into the sanitary sewer.
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
sump pump "pit falls" bubbler Plumbing 6 03-09-2011 08:45 AM
Sump pump float height dac122 Plumbing 8 12-08-2010 08:47 AM
How to test a sump pump sherlock Plumbing 2 10-02-2010 08:04 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
