Sump Pump Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2009, 07:38 PM   #1
Question
Sump pump issues
Old sump pump stopped working...not sure when but a month or so. We don't have a lot of water so it rarely came on anyway. Checked piping to ensure it was clear buy pushing smaller hose through it. Bought new pump and installed it...filled pit with about 6 inches of water...pit emptied quickly but made a subtle...but funny noise at the end. I refilled the pit with some water...pump made noise (buzzing sound) but did not empty water. Water also leaked out of the side of the pump...at the lower and upper housing connection area. Removed pump...some water gushed out of hose upon disconnect. Checked outside area...lots of water had come out...so the pipes are clear (or working). Pump appears to be full of water (internally). This was the same issue with the old one which I took apart prior to buying the new pump...the motor was full of water. Not sure if that is normal...but I think not.
The check valve appears to be working as well.
GeorgeHuhges is offline   Reply With Quote
Old 10-18-2009, 10:51 PM   #2
Rewards Points: 29
Do you have a 1/8" to 3/16" relief hole in the pipe before the check valve to prevent air lock? Is it plugged up maybe?
Dave Carney is offline   Reply With Quote
Old 10-19-2009, 08:56 AM   #3
Question
relief hole
There does not seem to be a relief hole...builders must of forgotten to do that when they put it in, which is probably one reason why my first motor siezed up.
So just drill a 1/8-3/16th hole below the check valve, i.e. between the check valve and the pump itself?
Also...if the sump gets water in it (as water was coming out the side of my new pump...any chance it will work again if I empty it out? Can they get wet internally (motor area)?
Last question...my original pump was a 1/4 hp submersible pump and I upgraded to 1/2 hp for this. I almost bought a effluent pump 3/4 hp which seems a little different (only one power cable). If this 1/2 hp is fried..can I use an effluent pump? Is there a real difference (safety etc.)?
Thanks,
George
Old 10-19-2009, 02:43 PM   #4
Rewards Points: 29
Yes, and drill it at an angle so that the water shoots down and not straight out when it's running.
I can't imagine that you hurt your new pump, it's submersible too, yes?
The effluent pump can pass solids to a certain size....that pump would be massive overkill in this application.
Tags
sump pumps
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump pump issues kraatzie Plumbing 1 03-19-2009 10:35 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
