Sump Pump Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2009, 11:20 AM   #1
Sump pump issues
I live on a one-acre piece of property in Southern Ontario. My concern is the frequency of which my sump pump goes on and off. It has not rained here in over a week and a half and the sump still works every 22 seconds (it was working every 4 seconds after rain and snow melt). All of my downspouts are 25' away from the foundation. I obviously have an issue with the high water table here. I need to know if I can cut into my weeping tile at the back of the house's basement; hire someone to dig a ditch below the basement depth; cut into the tile at the foundation; drain off the water coming into the pump well by diverting it away from the house into the new tile . . . I have over 250' of distance to run the tile with a vertical drop of over 11' . . . Do I put in solid ABS 3" pipe? Do I place the end of the pipe in to some kind of pit? Is there a sump well that can be placed in the yard which would allow me to place the new tile into it?
kraatzie is offline   Reply With Quote
Old 03-19-2009, 11:35 AM   #2
Remodeling Contractor
drain needs to run away from house at least 15 feet and "to light" or into a dry well. Which is a 6 X 6 X 6 hole filled with 2" stones and 3/4 gravel. Solid drain pipe is used, not ABS. This is a white thin pipe.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 10:48 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
