Old 01-31-2007, 08:38 AM   #1
sump pump issue
My sump pump is running like normal (sound wise) but not sucking up the water. It has been quite cold here (Nova Scotia) but I checked the outlet to the drain and it seemed fine. When I took off the pump the water that was stored in the pipe came back out so I figured there was no issues with the pipe line.
I am assuming its within the motor or pump and I am a complete novice so forgive anything I said that may sound elementary. It is a stainless steel model and one other time it wasn't running right but the noise made it obvious, this time its sounds as if its running as per usual but not sucking anything out.
Please advise
thorny is offline   Reply With Quote
Old 01-31-2007, 08:42 AM   #2
sump pump issue
You may need to do some disassembly. It COULD be that the impellor shaft broke or the impellor came loose and is not actually spinning to pick up the water.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
Sump Pump Help bolumenb Plumbing 4 01-22-2007 05:30 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
