Old 06-05-2012, 02:48 PM   #1
Question
Sump pump inflow
How can you tell if one of the inflow drains is cracked or broken? Why is the water that drains into the sump pump not filled with dirt? My sump pump is in a storage closet on a lower, finished level. Not so much rain that pump rarely kicks on. Sometimes bottom of pit dries up without my noticing it. Why should bottom of pit always have water?
aaccckkk!! is offline   Reply With Quote
Old 06-05-2012, 03:36 PM   #2
MarginallyQualified
Sump pump inflow
If installed correctly both the tub and all the pipes are surrounded by gravel
and even filtering membrane that will prevent dirt flowing in.
So... if you don't have dirt that is a VERY good sign.
Xray vision?
Sometimes bottom of pit dries up without my noticing it...
If your water table is low, or at least lower than the bottom of the tub, then there's no water to (normally) show up. Mine is like that. Dry as a bone 300 days a year.
Old 06-06-2012, 10:07 AM   #3
Sump pump inflow
Thanks for your reply - I'm actually an old homeowner but new to sump pumps. I think my next move will be to a rental!
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
