Old 01-04-2010, 09:30 PM   #1
Pro Flooring Installer
rusty baker's Avatar
sump pump hose
I get a lot of ground water into the basement of this 100 year old house. Limestone walls. The sump hose runs outside onto the ground. It freezes in the winter. Any way to insulate it?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-04-2010, 10:13 PM   #2
sump pump hose
I'd get a larger discharge hose.
Worse case, route it to your public sewer drain (assuming you don't have a septic system).
handy man88 is offline   Reply With Quote
Old 01-04-2010, 10:23 PM   #3
sump pump hose
My pump will only take a 2" hose. Against code to run into the sewer.
Old 01-04-2010, 10:24 PM   #4
Licensed Master Plumber
sump pump hose
You need to find a way to keep a pretty good pitch on the discharge pipe and to make sure the water does not puddle at the outlet. Running it into the sewer is illegal.
NHMaster is offline   Reply With Quote
Old 01-04-2010, 10:46 PM   #5
sump pump hose
The hose goes straight up 4', then out of the basement and downhill. It freezes inside the wall where it turns downhill.
Old 01-04-2010, 10:46 PM   #6
Civil Engineer
sump pump hose
Two common methods to prevent freezeup of the outlet pipe:
1. Run the pipe up to near the ceiling before penetrating the wall, then make sure the pipe has positive downward pitch after it leaves the house. The idea is to fully drain the pipe every time the pump runs.
2. Run the pipe underground at a slight upward pitch. You can elect not to use a backflow preventer, in which case the water in the pipe will drain backward into the sump pit when the pump stops. Some people install a backflow preventer, but put a small hole in the pipe (typically 1/8 inch) to allow the water to drain after the pump runs. The hole typicall is drilled in the pipe just after the backflow preventer, and faces down so any water forced out of the hole during pumping enters the sump pit.
Either of these techniques will eliminate freezeup since there is no static water left in the line. Of course, if you bury the line below frost depth, you will not have the freezeup problem either.
Old 01-04-2010, 10:54 PM   #7
sump pump hose
I know it's against code, but given that choice or water in the basement.....I'd go with......
In any case, if there's no threat of the freezing discharge to block up the 2" pipe, I would not worry about it.
Old 01-04-2010, 11:35 PM   #8
Xtreme DIY'r
sump pump hose
My pipe runs outside, then it dumps directly into a larger 3" pipe
Water seems to be collecting/staying in your pipe causing the problem
Do you have a check valve in place after the pump ?
That will keep water in the pipe
Old 01-05-2010, 05:55 PM   #9
sump pump hose
What you can do is bury a long 4" corrugate pipe right at the outlet form your house and extend that pipe, underground, all the way into an exit point.
The 4" pipe would be in the inlet from your direct sump discharge.
Sump pump pit water level --- problem de12 Plumbing 49 02-27-2011 02:42 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Permanent sump pump drainage hose jools Plumbing 8 05-11-2008 10:37 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
