Sump Pump Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2007, 05:14 PM   #1
Sump Pump Help
I have a sump pump and I don't see a way of setting the low level or high level for that matter but the pump works and then it makes a sucking noise(out of water) at the end always and I would like to somehow raise the level so that the pump stops prior to running out of water.
How can I change the low level so that the pump does not suck air up and make a big noise.
Thanks.
bolumenb is offline   Reply With Quote
Old 01-21-2007, 06:13 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Is the float stationary or strapped to it's side?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-21-2007, 08:08 PM   #3
Don't see anything that moves up or down with the water so it must be stationary. Must have a switch somewhere but can't find it.
Old 01-22-2007, 05:01 AM   #4
Journeyman Plumber
Must have a pressure switch built-in, if so you can not adjust it.
Old 01-22-2007, 04:30 PM   #5
Float may have to be puchased separately. Picture would help alot.
gitnerdun is offline   Reply With Quote
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 08:32 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
Sump Pump Question cibula11 Plumbing 9 04-26-2007 03:28 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 09:36 AM
