#1 |
Sump Pump Help
My daughter is house/dog sitting and the sump pump in the basement of the house has stopped working due to severe thunderstorms we have been having everyday. There is a few inches of water and I'm wondering is it safe for me to wear boots and try and reset the sump pump and also check the circuit breaker board? The people she is housesitting for didn't leave an emergency plumber or electrician #. Don't know how long the pump hasn't been running (probably a day or so). Thanks so much for any help.
#2 |
Sump Pump Help
I would never say any activity was absolutely safe. If you feel uncomfortable investigating the sump pump, don't do it. That being said, one should be able to check it out safely. Thunder storms often cause Ground Fault Interupters (GFI's) to trip, but not usually circuit breakers. Circuit breakers are designed to respond more slowly to overcurrent than a GFI responds to a possible ground fault.
By all means start by checking the circuit breakers. If they look good, see if the sump pump is pluged into a GFI outlet and reset that. Good Luck. |
#3 |
Sump Pump Help
Not being able to see the situation I'd advise against it. Stick a submersible pump in the basement to drain the water then go down.
Also is your sump pump submersible? If it isn't do not try to turn it on. I've seen people do that one before. Fortunately they only burnt out the pump and not themselves. |
#4 |
Licensed Master Plumber
Sump Pump Help
Go with Marlin's idea. We don't want to get anybody electrocuted from lack of knowledge.
Mstplumber Check out my goofy video for my new To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
| Display Modes | |
| sump pump issue | mikehende | Plumbing | 15 | 02-15-2008 07:36 AM |
| Foundation drain and sump pump | slatergrl | Plumbing | 3 | 02-10-2008 10:36 AM |
| sump pump continuing running | deck hand | Plumbing | 2 | 01-16-2008 05:35 PM |
| Sump Pump Concept Questions | dshuster | Plumbing | 1 | 11-22-2007 09:47 PM |
| looking to upgrade sump pump | coeng | Plumbing | 14 | 06-04-2007 04:08 PM |
