Sump Pump Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2008, 04:03 PM   #1
sump pump help
due to landscaping and outdoor cement..i have to pump my sump water quite a ways... i need some help on lift (or it may be called head pressure)
my sump pump must first lift the water 12 feet..then turn 90 degrees and run horizontal for the length of the House ..about 50 then another 90 up 1.5 feet and another 90 out through the wall...
i can buy a sump pump with a 25 foot lift..will this work in this situation..i do not know how to convert horizontal runs into the equivlent of lift
thanks for any help offered
billie_t is offline   Reply With Quote
Old 03-20-2008, 04:23 PM   #2
electrical contractor
Rewards Points: 150
is the horozontial run level or is it up hill? if it is up hill measure difference in elevation from one end to the other and add this to your verticle measurement, if the run is level you will incur a small ammount of friction loss, not enough to worry about in that short of a run.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-20-2008, 04:59 PM   #3
I think you'll want to try to get all of your vertical first, then the horizontal. It may not be feasible in your situation. I'd guess that you'll end up with a lot of water sitting on your check valve and the tube would pretty much be full all the time, just waiting for the next pumping of water to expel what's been sitting in the pipe.
perpetual98 is offline   Reply With Quote
Old 03-20-2008, 09:18 PM   #4
thenaks for your help fellas..the horizontal run will be close to level...it will be running above a false ceiling..there may be a bit up in down in there to get around things but only a couple of inches i would think
i thought i read somewhere that pushing water (even level) added to "head pressure" because of friction but maybe i was misunderstanding or in an altogether different world at the time..thanks again
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
Sump pump re-hab mpking Plumbing 1 11-08-2007 12:29 AM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
