Sump Pump Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2011, 04:46 PM   #1
sump pump help
Have a outside sump pump that runs to a near-by brook . The piping goes the length of the yard and into a 4 inch pipe that goes through the berm that is buildt up to keep the brook from flooding ..My question is:
sometimes the water level gets above 4 inch pipe so sump has no where to pump to .I was wondering if I put a 90 degree elbow on the 4 inch pipe and 3 foot extension pointing down stream would the current pull the water if the pump was running(almost like a vacum)?? even though the water is above the outlet??
thanks
Craig
chambers138@comcast.net..
craigor1 is offline   Reply With Quote
Old 04-03-2011, 01:37 PM   #2
Rewards Points: 1,580
Nope.
bob22 is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
