Sump Pump Gurgling - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2013, 08:46 AM   #1
Rewards Points: 160
I have a sump pump that is very loud due to the pipe setup. When it initially turns on, there's a loud sound as the air is purged out of the pipes. After it shuts off, there is a gurgling sound as air bubbles go into the pipes. I've installed 2 check valves, along with an air admittance valve, but it hasn't helped. The area between the middle check valve and the foundation wall is inaccessible due to a large cabinet someone put up. Is my only option to extend the pipe through the foundation wall, install the air admittance valve at the elbow, then drop down into the ground on the outside of the house?
Also, the pipe empties open ended into the front yard. I'm not sure if moving the last check valve to this opening would help with anything. All pipes are 1-1/2 PVC and ABS.
matt151617 is offline   Reply With Quote
Old 04-14-2013, 09:02 AM   #2
Rewards Points: 13,712
Only need one check valve at the pump.
Why the AAV?
Old 04-14-2013, 10:12 AM   #3
Rewards Points: 160
There's a vacuum forming, causing the gurgling. I drilled a hole in the pipe outside the house before installing the AAV and you could hear a whistle as the air was sucked in. How do I counteract this vacuum?
Old 04-14-2013, 10:56 AM   #4
Rewards Points: 32
Like Joe said, you only need one check valve near the pump. Are you using the check valves to keep the pipes full of water?
Dan
djlandkpl is online now   Reply With Quote
Old 04-14-2013, 10:59 AM   #5
Rewards Points: 160
Yes, but the noise is still coming from the small section between check valves.
Old 04-14-2013, 11:19 AM   #6
Rewards Points: 32
This is a guess not knowing the check valves installed. Since the 2nd and 3rd valves are mounted horizontally, I suspect water is still getting past the flappers. You don't need an AAV.
Dan
Old 04-14-2013, 11:33 AM   #7
Rewards Points: 1,950
An AAV is worthless in your situation. They seal up tight with positive pressure. Remove all the extra check valves and get a good solid one by the pit above it would be best in a vertical position. It also helps to drain the pipe toward its point of disposal once you turn horizontal.
Ghostmaker is online now   Reply With Quote
Old 04-14-2013, 12:24 PM   #8
Rewards Points: 160
The AAV is at least helping to release the vacuum and eliminate some but not all of the gurgling. The system originally had only 1 check valve about 1 foot above the pit. The other valves were added in later to address the gurgling noise.
Old 04-14-2013, 12:30 PM   #9
Rewards Points: 32
Water is getting past one of the check valves sine you are hearing air get sucked in.
Dan
Old 04-14-2013, 03:40 PM   #10
Rewards Points: 160
I was under the impression that any drain required air to be admitted into the system or it would not function properly. This system is independent of the household plumbing and not connected to a stack or any other vent.
A friend who was a former plumber told me drains hate 90 degree bends and to either install 45's, use flex pipe, or extend the pipe and elbows to outside the house to eliminate the noise.
Old 04-14-2013, 03:55 PM   #11
Rewards Points: 32
A gravity drain needs air like you house drains. Your sump pump is mechanical. The water is being pushed out. Adding air adds noise. Stop the pump and the water stops. Water is getting past your check valves and that is creating the vacuum. Check your valves to see if the work in a horizontal application.
Dan
Old 04-14-2013, 04:07 PM   #12
Rewards Points: 160
I'm positive it's not the check valves. The problem existed before those were ever installed.
Old 04-14-2013, 06:06 PM   #13
Rewards Points: 32
Assuming the vertical check valve is functioning, prior to adding the horizontal check valves any remaining water in the horizontal piping would drain out from gravity. Once a big enough air bubble got into the pipes, it would drain most of the water. When the pump started up, sloshing sounds.
If you put in check valves that aren't suited for horizontal use, nothing has changed and the water is still draining from the horizontal pipes.
One way to test this is to run the pump until you have water coming out of the discharge. Turn off the pump wait 10-15 seconds for the water in the vertical pipe outside to empty. Stick a bucket under the pipe and wait. See if a water fills the bucket. Also check the vertical valve by running the pump and shutting it off. Listen for water running back into the sump.
Dan
Old 04-14-2013, 07:29 PM   #14
Are they swing checks or spring checks?
A simple one like this is what you should have.
http://www.bing.com/shopping/flotec-...mp&FORM=CMSMEE
Old 04-14-2013, 09:32 PM   #15
When your pump fires the AAV will close as it is designed to do.
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 12:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
