Sump Pump Gets Stuck In Running Position - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2009, 06:10 AM   #1
sweaty
Rewards Points: 266
Sump Pump Gets Stuck in Running Position
My sump pump gets stuck in the running position and the float ball won't come down. I don't want to burn out the motor. It is most likely the original pump (1977). Can I unstick this thing?
sweaty is offline   Reply With Quote
Old 04-09-2009, 07:02 AM   #2
If it is the type that the float rides on a rod, clean and lubricate the rod. If it is the type that the switch is in a ball on the end of a cord, make sure there is noting that it can hang up on. But if the pump is that old, I would consider a new pump.
Old 04-09-2009, 07:35 AM   #3
the Musigician
DangerMouse's Avatar
if this is the fact, and cleaning it does not fix it, they make float switches you can mount to the existing w/o having to replace the pump.
DM
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 10:33 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
