Sump Pump Drainage Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2011, 10:54 AM   #1
Lightbulb
Sump Pump drainage issue
Hey all-Recently I have been informed by my city public works that my sump pump draining into my sewer is against code and must be changed within 30 days. Knowing that the house AND sump pump existed before the sewer pipe I went searching for the old discharge. I have found one unexplained pipe that runs out my basement wall and halfway through my yard and because for some reason it is now attached to a water pipe(thinking someone had a fountain at one time)I know it is flushed and ready. My question is the pipe extending through the wall is 1" to 1 1/4" and it's flexible...Is it feasible for me to attempt to attach my 2 1/2" pvc coming out of my sump pump to this drainage hose??? Really can't afford a plumber right now and since I'm a city employee I can't really drag my feet on this...
Megatron is offline   Reply With Quote
Old 05-31-2011, 04:50 PM   #2
Rewards Points: 1,668
TRy it and see what happens. Get a couple of 5-gal buckets with water and empty one into the pit and see if it pumps through without issue. If the line is clear it should come out. 2 1/2" discharge is pretty large for most sump pumps, usually 1 1/2" is used; will need an reducing fitting at least.
bob22 is offline   Reply With Quote
Old 05-31-2011, 09:28 PM   #3
Rewards Points: 1,088
How did your city PW dept know that your sump was dumping into the sewer?
handy man88 is offline   Reply With Quote
Old 05-31-2011, 10:56 PM   #4
Run a new line to an open area in the yard or somewhere. I would not reduce the size of the discharge, That puts more stress on the pump and voids the warranty of the pump and 2 1/2 inches does sound odd.
NickFixit is offline   Reply With Quote
Old 06-01-2011, 12:21 PM   #5
Rewards Points: 1,542
It would probably be better not to use the unexplained pipe yet. It might end up outside quite close to the house and the water poured down it could make its way back to the house drainage system and sump (pit).
Temporarily run a new line on the surface and ending some distance from the house if possible.
Old 06-01-2011, 05:05 PM   #6
Allan: Where is your sense of adventure?
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 10:17 AM
How to test a sump pump sherlock Plumbing 2 10-02-2010 08:04 AM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
Sump pump drainage question famdog Plumbing 1 01-05-2009 01:42 PM
sump pump issue thorny Plumbing 1 01-31-2007 07:42 AM
