Sump Pump Drainage - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2008, 03:23 PM   #1
Sump Pump Drainage
I just recently just moved out into the country and have acrage. Well my sump pump which is in my crawl leads out to my backyard to drain. So now I have a HUGE mosquito problem! The area behind my yard is wooded. Could I run the pipe into there to drain? or would there still be the mosquito problem? I dont have a city sewer system to run it to. Please help!
karabou216 is offline   Reply With Quote
Old 06-20-2008, 03:42 PM   #2
RippySkippy's Avatar
You will most likely have the mosquito problem...but it will be re-located to a place further from the house. If you're not dealing with much grade, you can pump the water as far as you'd like. It would be best if you can work with gravity. I HATE mosquitos!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-20-2008, 03:45 PM   #3
Luckly its really sandy by me.. Demotte Indiana. I need kind of a easy solution... see.. my boyfriend is at work from 7am (1 hour travel time for both of us) till 11pm (owns his own shop) so i'm left to do all of this... im 22 and in school and work.
Old 06-20-2008, 04:08 PM   #4
Registered User
Termite's Avatar
Try to drain the sump on a hill or slope if you have one. Wet ground won't breed mosquitos, standing water will. If you can pump the water to an area where it will not accumulate and stand on the ground's surface for a prolonged period, it'll help.
Another option would be to dig a hole a few feet deep and a few feet in diameter (above the water table) and fill it with rocks, bricks, gravel, etc. Then cover it with a good layer of gravel and soil and run your sump drain into it. The water will leech down into the pit and can be slowly percolated into the surrounding soil, unless the soil is solid clay.
Old 06-20-2008, 04:28 PM   #5
Thanks, Ill try the rock solution.
Sump pump drainage problem sk8z Plumbing 6 11-29-2008 10:09 PM
Permanent sump pump drainage hose jools Plumbing 8 05-11-2008 09:37 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
