Sump Pump Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 10:20 AM   #1
Question
Sump Pump Drain
Had a device in my sump pump drain that resembles an Ice Guard. It allows water to flow should the 4" drain pipe become plugged or frozen. I hit it with the weedeater and need a replacement.
Ice Guard is a device of Basement Systems and they will not sell to an individual without them installing.
Does anyone know where to obtain a similar device?
Corngrower is offline   Reply With Quote
Old 04-11-2012, 10:23 AM   #2
Trucon01's Avatar
Rewards Points: 510
You have any pictures of what it looks like and where it is located in your system?
Trucon01 is offline   Reply With Quote
Old 04-12-2012, 09:50 AM   #3
Sump Pump Drain
Do Not have pictures. The device looked like a PVC reducer from 1.5" pipe to 4" pipe (PVC) that had walls between the pipes that were slotted. Thus if drain was plugged the discharge water from sump pump would flow out on the ground.
Old 04-12-2012, 10:52 AM   #4
Rewards Points: 13,456
Look like one of these?
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Sump pump...how does it work?...pics MecGen Plumbing 6 06-18-2011 07:28 AM
Question regarding floor drain and sump pump combo vetting Plumbing 9 07-29-2010 01:10 PM
Sump Pump / Outdoor drainage HELP! Shamrexm Plumbing 0 06-15-2010 05:52 PM
Sump pump drain through vinyl siding Swillbee Building & Construction 21 10-01-2008 11:17 AM
