Sump Pump Discharge To Pond?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2013, 08:26 AM   #16
Rewards Points: 774
Originally Posted by djlandkpl
Might be a pain due to the distance for wiring, but what if you went with the drywell route with a sump pit on top. Stick a pump in this area to handle the overflow when the drywell can't keep up.
I'm not sure what you mean by wiring. The check valve would be a rubber valve connecting to runs of 1 1/2 in. PVC discharge line. I just don't want to create another issue since I don't know if this is possible. I'd spend $10 on a check valve if I know something is going to be damaged by my attempt.
cibula11 is offline   Reply With Quote
Old 07-14-2013, 09:20 AM   #17
Rewards Points: 34
Sorry if I wasn't clear.
I'm suggesting moving the water in two stages.
1) Basement to a new drywell.
2) If drywell fills up, a new pump within the drywell pumps the water through the incorrectly sloped pipingn.
From what I have read, 2 check valves can cause an air lock to form between the two valves. The lock would stop the water flow when the pump was working.
Dan
djlandkpl is offline   Reply With Quote
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
sump pump discharge Curious Homeown Landscaping & Lawn Care 4 10-25-2009 08:38 AM
how/where to discharge sump pump downers Plumbing 8 06-18-2008 06:18 PM
