Sump Pump Discharge To Pond?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2013, 03:58 PM   #1
Rewards Points: 790
Sump Pump Discharge to pond??
I realize pics will help, so I'll get on that...but in the mean time.....
Our sump line runs away from our house (south)and USE TO run into a nearby field. However, before we moved in the farmer asked the homeowners to move it to a different place (west). Long story short, I noticed our yard a bit sloshy in a couple of places so I investigated, found the point where they went west with the new line and cut the pvc. Water came gushing out, telling me the slope was not at all proper. Now, instead of ripping up over 100' of buried PVC and sloping it correctly, I thought about creating a dry creek bed/pond and just forget the whole thing. Is this possible?
I'd essentially be cutting the line about 30' from the field and digging out a pond like (albeit small pond, more like a koi pond) I'd say 8-12 inches down and then have the water empty into this pond/basin. I still could use the old line that runs into the field as an overflow if needed...our pump runs quite a bit.
Thoughts?
cibula11 is offline   Reply With Quote
Old 07-03-2013, 05:17 PM   #2
joed's Avatar
Rewards Points: 13,368
The overflow would not work since you said it runs down hill into the potential pond and not away from it.
Old 07-03-2013, 07:16 PM   #3
Rewards Points: 14,026
Also would be a great place to bred mosquitos.
Old 07-04-2013, 07:12 AM   #4
DIY staff
Rewards Points: 7,174
Carp eat mosquitoes--- post a picture---could work---but you must make sure there is a free fall pipe feeding the pond--if not you would be at risk of siphoning the pond into your basement if the back flow valve ever failed.
Old 07-04-2013, 08:53 AM   #5
An old Tradesmen
Rewards Points: 7,832
8 to 12" deep. How wide?
Old 07-04-2013, 09:59 AM   #6
Rewards Points: 790
Well, I can make it just about as wide as I need to. At minimum it would be about 6 ft. diameter, but I could go a bit larger if needed.
My biggest concern is making sure the water isn't sitting in the pond area for too long. I'd rather it be more of a rain garden that allows the water to seep into the ground gradually. I also worry about winter and what happens when all that water is being pumped into below freezing weather.
Old 07-04-2013, 10:03 AM   #7
An old Tradesmen
!2" by 6 foot, is 6 cu ft. Which would hold a rounded up 45 gallons.
You said your sump pump runs a lot. How often is a lot, and how many gallons does it pump out each time.
Old 07-04-2013, 12:09 PM   #8
Rewards Points: 790
NOt sure on how many gallons each time. I'd have to check. During really wet or rainy weather it runs every 5 min or so. We haven't had heavy rain for about 2 weeks and it runs a couple of times a day.
I don't think 45 gallons would hold it, although if it were draining as it was emptying into the pond, I guess it might work. That's why I thought if I had an overflow pipe just in case it was pumping out an abnormally high amount I'd still be okay. Like I said I could double that size if needed.
Old 07-04-2013, 12:25 PM   #9
joed's Avatar
6 foot diameter at 1 foot is 28 cubic feet. 210 gallons
The Following User Says Thank You to joed For This Useful Post:
Oso954 (07-04-2013)
Old 07-04-2013, 02:08 PM   #10
An old Tradesmen
LOL, forgot to do the circle area. Thanks for the correction.
Old 07-04-2013, 02:29 PM   #11
Rewards Points: 2,042
Only concern I have is how much do you like mosquitoes?
Old 07-04-2013, 03:25 PM   #12
Rewards Points: 790
I like them a lot more than a sloshy lawn and a wet basement
Not sure if this will even be the route I take, but wanted to see what others ideas and thoughts were. This "pond" will be about 100' or more from my house and we live on 2.5 acres, so the bugs are already here.
LIke I mentioned in my first post. My options seem to be:
1. reroute 150' feet of already buried pvc discharge line and excavate to the appropriate slope.
2. Anger the farmer where the line is currently and temporarily run to (his field).
3. Pond
4.???
Old 07-04-2013, 05:52 PM   #13
joed's Avatar
4: drywell - big hole full of stone and covered with lawn.
Old 07-13-2013, 03:22 PM   #14
Rewards Points: 790
I've considered this. I wonder, however, if a drywell would be a good idea when there's hundreds of gallons of water per day (on very wet days).
Here's another question for someone.
Could I or can you add a second check valve in the discharge line? The second one would be added where the low point was9 (50 ft from the house). This was I could get the water past that point, but none would come back towards the yard. Can this be done?
Old 07-13-2013, 03:38 PM   #15
Rewards Points: 44
Might be a pain due to the distance for wiring, but what if you went with the drywell route with a sump pit on top. Stick a pump in this area to handle the overflow when the drywell can't keep up.
Dan
djlandkpl is offline   Reply With Quote
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
sump pump discharge Curious Homeown Landscaping & Lawn Care 4 10-25-2009 08:38 AM
how/where to discharge sump pump downers Plumbing 8 06-18-2008 06:18 PM
