Old 05-27-2012, 07:25 PM   #1
maa
sump pump discharge pipe
what is the maximum length of 1.5 inch discharge pipe that can be used without damage to pump
maa is offline   Reply With Quote
Old 05-27-2012, 07:34 PM   #2
A lot depends on what direction the pipe is run.
Look on the pump or go on line and look up the pump and look how much head the pump can pump. Head is with the pipe straight up from the pump.
No one here know what brand pump, or what model you have so just Google for the info.
maa (05-27-2012)
Old 05-27-2012, 07:47 PM   #3
MarginallyQualified
The issue is the distance from the pump UP to where the flow starts to run downhill.
From that point it can run 1000 feet downhill if you desired.
Most residential sump pumps will have no problem pushing the water up
the 10 feet or so needed by most outlet piping. Don't forget the check valve.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 11:51 AM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
