Sump Pump Discharge Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2011, 01:55 AM   #1
Rewards Points: 162
I have a sump pump that connects to 1.5" PVC. It goes straight up out of the pit about 7 feet, then runs along the ceiling approximately 20 feet to the foundation wall. Just before the wall it bends down 90 degrees, drops about 3 feet, then bends 90 degrees again and exits through the foundation and into the ground.
Problem is, when the pump shuts off, about 20 seconds later there's a very loud gurgling/bubbling noise (sounds like someone rapidly blowing big air bubbles underwater) that comes from the pipe near the foundation wall. It seems to do 5 or 6 "bursts" or rythymic cycles of this noise then stops. I installed another check valve near the wall but it didn't help. How can I stop this?
matt151617 is offline   Reply With Quote
Old 09-19-2011, 05:34 AM   #2
DIY staff
Rewards Points: 7,174
Add a vent to the pipe.
Old 09-19-2011, 11:35 AM   #3
Rewards Points: 162
What's the easiest way to do this? The area next to the foundation is very tight due to a large built-in storage cabinet. The sewer vent pipe is 30 feet or so from the sump pipe. Attaching it outside would involve drilling through the foundation and digging a hole.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump pump float height dac122 Plumbing 8 12-08-2010 08:47 AM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
how/where to discharge sump pump downers Plumbing 8 06-18-2008 06:18 PM
