Old 05-24-2010, 08:01 AM   #1
Sump Pump Discharge
How can I protect the outlet of a sump pump discharge to the exterior so things don't back up into it or a rat doesn't decide to setup shop?
smata67 is offline   Reply With Quote
Old 05-24-2010, 08:43 AM   #2
Civil Engineer
Sump Pump Discharge
Most sump pumps use a 1 - 1/2 inch outlet pipe, or possibly a 2 inch pipe. That is what I have on my system, and I run it directly into a 5 gallon bucket with 1/2 inch holes cut in the sides. The pipe actually discharges into a few big rocks on the bottom of the bucket, works fine, no rats. If you are really concerned, you can buy a plastic housing to cover the outlet that deters rodents.
Old 05-24-2010, 08:47 AM   #3
Sump Pump Discharge
Put an adapter on the end to connect to a slightly larger diameter pipe, and then put screening on the larger diameter open end. Use 1/4 inch wire mesh rather than window screen.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-24-2010, 02:36 PM   #4
Sump Pump Discharge
An adapter with a screen like AllanJ mentions is your best option if your really that concerned about pests entering your discharge line. As long as the pump is cycled once a month, you won't have any problems, and if something does get in there, the next time the pump kicks on, it will be "evicted" in no time!
The Engineer is offline   Reply With Quote
Old 05-24-2010, 06:35 PM   #5
Sump Pump Discharge
What about snow? My sump currently empties into the waste stack, so I have not had the pleasure. We did have 30" here last year and the sump ran quite a bit.
Old 05-24-2010, 06:59 PM   #6
Xtreme DIY'r
Sump Pump Discharge
The waste stack for Town sewer ?
That's a violation in most areas, here its up to a $1500 fine
Old 05-25-2010, 09:40 AM   #7
Sump Pump Discharge
Been that way for 60 years...
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sump Pump Discharge in MN livinginthepark Plumbing 5 11-12-2008 01:04 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
how/where to discharge sump pump downers Plumbing 8 06-18-2008 07:18 PM
