Sump Pump Discahrge Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2009, 08:37 PM   #1
Sump pump discahrge line
I am working on my father-in-law's home. I have installed a sump pump in the basement with the discharge (1.5" PVC) coming out of the back of the house directly over and area where I will be pouring a concrete patio. I don't want the sump discharge spilling over the patio so I plan on running pipe under the concrete. The patio is approximately 10' wide and extends across the back of the house. I will need to run the pipe approx 16' to clear the patio and other areas that I do not want water pooling. This is where I have questions. How deep should I run the pipe (we're in Michigan)? What size pipe? Should I run the pipe into a dry well? What about a pop-up overflow? Thanks for your help
helpingdad is offline   Reply With Quote
Old 07-25-2009, 08:45 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I would try to reroute the sump discharge to a different exterior wall instead of running it under concrete due to freezing. Not sure of your frost depth but I would say don't do it. Find another wall
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 01:01 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 09:36 AM
