Sump Pump Crock With No Pump Or Drain Installed - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2011, 01:13 PM   #1
sump pump crock with no pump or drain installed
If a home has a sump crock but no sump pump or drain installed to take the water out and away from the house, what's the point in the builder installing just the crock? I see this as a bacteria trap and health issue. Is this legal?
mauragolf2 is offline   Reply With Quote
Old 06-24-2011, 01:28 PM   #2
Civil Engineer
Rewards Points: 4,856
There may at one time have been a sump pump, which failed and was not replaced. It is also possible that the builder never installed the pump, left it to the new homeowner. As for legal, ask your local building inspector.
Old 06-25-2011, 07:54 AM   #3
Rewards Points: 1,538
Does water collect in the crock?
Even when the sump pump is installed, the crock (if it does collect water) will almost never be completely dry. If you were concerned about bacteria you would still have to put in bleach from time to time provided that that does not deteriorate the pump or the pipes.
Old 06-25-2011, 08:16 AM   #4
A Little Of Everything
Rewards Points: 1,364
Lots of variables here. Age of house, type of "crock", location, etc.
My guess is that the concrete contractor was instructed to install the crock when he poured the floor, but nothing more was ever done.
Is there electric service to the area? Hole in the header joist, or anything like that?
DrHicks is offline   Reply With Quote
Old 06-25-2011, 08:18 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
when I built my house, I made sure they put in a sump pit. My intention was to put in a sump pump but I have yet to install that pump because it never has water in it but I'm sure glad it is there just in case.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-25-2011, 08:30 AM   #6
I'm guessing that's the scenario the OP is looking at.
A good friend of mine recently bought an almost new house out in Colorado. All the plumbing for a bathroom/laundry room/utility room was stubbed into the floor in one corner of the basement.
Sump Pump Hole Wet but no Sump Pump judylong1 General DIY Discussions 4 06-03-2011 09:08 AM
Outdoor Sump Pump.... JRoot Plumbing 6 07-04-2008 06:35 AM
What is it? A Sump Pump or Tub Drain ameleus Plumbing 13 05-04-2008 06:12 PM
Drain to outside for Hot Water Tank with sump pump? BlairK Plumbing 1 10-04-2007 06:46 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
