I put this into plumming because I think this is the best area to get some help!
My buddy has this sump pump with two pumps in the bottom? One is a back up?
The water is very clear as it only pumps ground water up and out.
The main pump works off a large float, this one works fine. When the float is raised.
The little pump has me stumped. It runs all the time.
I can't see where a drain line come from this pump it does not seem to be conected to the main pump except by a bracket.
I unpluged this smaller pump and let the sump fill, At the right height the larger pump kicked on. I quickly re pluged in the small pump electrical cord in and this pump ran like a wizzz and emptied the sump out fast.
I took a stick and moved the sediment from around the two pumps, this did not make any differance.
I can un screw the flex hose from the pvc and lift the pumps put.
put I have never ever, screwed around with a sump pump.
It looks real easy to do and clean but the second small pump baffels me???
Anyone else have two pump system.
I won't get upset if you can help me. I Plan on pulling these pumps out thur.
for a look see!
Deck hand
for a look see!
Deck hand
