#1 |
Sump pump concerns
I have a sump pump in my basement,i was getting alot of back up from discharge pipes,si I disconnected them and ran drain line from discharge pipe out side.i am still getting waterback into the pit tho.the water isnt comming from the drain tiles under the basement floor,and the plumber I had out,said the check valves are fine....he said the water is from whats left in the pipe below the check valves.so with that in mind...i used shop vac to suck out and clean the pit,great all water out,well 11 hours later...theres water I. The pit,and its not ,coming in from drain tube under basement floor,and theres no plumbing /water or sewer lines connected to the pit,and the water when ejected from the pit draines into tube to the back of property.what gives? This is driving me absolutelu crazy!
#2 |
Sump pump concerns
When I say at the begining back up,i mean that thr drain tiles/black4" plastc tubing going to drywell was clogged.so I capped off old,and ran new line above ground for now
#3 |
Sump pump concerns
I have a similar sump pump setup I installed while back, but I am not sure what you are asking?
Sump pump is there to collect underground water to be pumped out. If you wet vac'd your sump pump pit but 11 hours later there was water, I would say it is doing it's job? I think the check valve is there so that the pump doesn't run over and over with that vertical column of water. If you normally do not have water in your pit, check to make sure that your discharge pipe from the sump pump is not loose and is properly dumping water into that 4" pipe outside. Also, I would make sure the end of that 4" pipe is as far away from your basement corner as possible (hopefully grading away) |
| The Following User Says Thank You to allthumbsdiy For This Useful Post: | Hutchinsonhut (09-11-2012) |
#4 | |
Sump pump concernsQuote:
#5 |
Sump pump concerns
I would not worry about water in the pit. The pit is supposed to be ready to collect water at all times (and the pump ready to get rid of the water when the water level gets high enough).
A crack in the bottom of the pit letting water in the ground seep up into the pit is not a defect.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 09-12-2012 at 10:34 AM. |
| The Following User Says Thank You to AllanJ For This Useful Post: | Hutchinsonhut (09-11-2012) |
#6 | |
| Display Modes | |
| sump pump "pit falls" | bubbler | Plumbing | 6 | 03-09-2011 09:45 AM |
| Voltage dip when sump pump starts | Josh61513 | Electrical | 4 | 04-03-2009 11:32 AM |
| Foundation drain and sump pump | slatergrl | Plumbing | 3 | 02-10-2008 10:36 AM |
| Sump pump re-hab | mpking | Plumbing | 1 | 11-08-2007 12:29 AM |
| looking to upgrade sump pump | coeng | Plumbing | 14 | 06-04-2007 04:08 PM |
