Old 12-03-2011, 12:33 PM   #1
Sump pump chugging
How do i keep my sump pump from chugging while the water is draining after the pump shuts off, get a terrible boom ...boom...boom for about a minute after it shuts off, got a check valve above the pump in the pit, went as far as installing a check valve outside thinking it needed more air to help clear the line faster, helped but still getting that annoying banging
JEREMY88 is offline   Reply With Quote
Old 12-03-2011, 04:56 PM   #2
Super Moderator
Sump pump chugging
The run is to long ---add a vent or change the pitch of the pipe---
add a photo of the piping---inside and out----Mike--
oh'mike is online now   Reply With Quote
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
